Ads749r Posted August 8, 2013 Report Posted August 8, 2013 Hi all I have mk3 2000e that has not turned a wheel in 15 years. What would you recommend to get the engine running. I'm going to drain all the oil, coolant, transmission oil (automatic) and fuel and brake fluid. What else will I need to do. Will I need to do something to the carb ie from some fluid in. Sorry if it sounds silly but its the first old car I've worked on . Thanks in advance
