jdmsport Posted July 20, 2014 Report Posted July 20, 2014 Sierra 3dr rally shell very straight had little use.It has full weld in roll cage works style,seam welded jacking points,clean doors,bootlid,spoiler,bonnet (non cossie),no other panelsFull engine including all ancils,205 block,3 bar map sensor,(no turbo),l8 ecu with stage 3 chip,green injectors,ecu wiring harness,bailey alloy header tank,alloy breather system,alloy swirl pot,new rs500 intercooler,avo rear shocks,koni front shocks,all x member included,7.5" rear cossie diff with group a mount,cossie 4 pots for front,6 paddle clutch,(no gearbox),standard radiator,all cossie pedal box,steering column,dash,dash clocks etc included,3" mongoose exhuast£5495ovno
