has anyone got a tandem brake master cylinder in good working order for a mk 1 escort ,to fit on to the servo tower .
i have i think a mk2 cortina one  which is longer and stops the tower being droped down to fit 40s.
thanks
I don`t have it but , you will need to know what brand you need ATE or Lucas , you can also check this to measure the  distance  between the dreads , if it is 6cm than ik will be Ate and if it is 8cm than it will be Lucas.
I think that these 2 are the only one`s that there are ?  but sure off course.
And check size how much the cilinder is , probalby is there difference between brake drums and brake discs ?
