Same happened with mine.
In my situation it was the nut that came loose on the back of the lock behind the barrel.
I took the rear seat back out and attached loads of extension bars to a socket and poked it through 1 of the small holes in the metalwork behind the seat and a torch through another. It was a mission!
Hope that helps.
  • Like 2
Same happened with mine.In my situation it was the nut that came loose on the back of the lock behind the barrel.I took the rear seat back out and attached loads of extension bars to a socket and poked it through 1 of the small holes in the metalwork behind the seat and a torch through another. It was a mission!Hope that helps.
It was exactly that...sorted out now cheers mate
  • Like 2
Glad you sorted it.
It takes a fair few extension bars with a few wobbly joints to get the correct angle hey ;0)
Hope you put a bit of loctite on the thread too.
