gazcos Posted July 30, 2015 Report Posted July 30, 2015 I've got a Mk1 Cortina here I'm probably going to put a nice Zetec in but before I start collecting parts I thought I'd ask if anyone has a nice engine package they want to sell. Zetec, Crossflow, Carbs, Throttle bodies. I open to suggestion, what have you got?
mk2 mike Posted July 30, 2015 Report Posted July 30, 2015 Ive got an Ashton built 1700. Comes with twin 45s and linkage on a manifold. 105speed stainless exhaust manifold (no system as I'm using it on my zetec) hi torque starter, bestek ign system and dizzy. Higher amp alternator, Alloy rocker cover, silicone rad hoses, engine mounts, Clutch, lightened flywheel. It's a great little engine. Bad points are it can do with a repaint, and one of the lugs where it bolts to the bell housing has broken off. I do still have it and have been told it can be repaired if needed but not necessary. It's probably done less than two thousand miles since built and had three oil changes. I'm looking for £2500 for the lot.
vince Posted August 7, 2015 Report Posted August 7, 2015 i have a brand new 1.8 blacktop zetec this is a genuine factory engine £475 i also have a holbay pinto turbo engine and t5 gearbox ecu etc offers
