1300gt Posted February 17, 2016 Report Posted February 17, 2016 Hi all old school ford, I have for sale eeciv T25 escort Cosworth plenum. This item is higher flowing than 2wd -4wd item as STD. Elbow has been ported by a well regarded tuner and then powder coated gold. This item will comes with a lightened throttle cable bracket as per the pictures and cometic foam alloy reusable high quality gasket. Only check fitted. Never run. A2-70 stainless steel cap head fixing bolts for bracket supplied. This plenum as STD has been proven to flow 500+ hp on accurate engine dyno. Part located Guildford surry. GU24 £190 delivery uk mainland Details & pics. Call mark. 07977409910.
1300gt Posted February 17, 2016 Author Report Posted February 17, 2016 Was all going in a mk1 escort, but change for plan reason of sale. Thanks. Mark
1300gt Posted April 15, 2016 Author Report Posted April 15, 2016 Forgot to say this comes with anembo engineering alloy plenum spacer as pictured. As inner wall of plenum is moved away from Trumpets and quoted to lower charge temps
