Hi All,
Looking for some tips on below.
Escort Mk1 (RS2000 Engine) been sitting up my unit for about 18 months and not driven anywhere.
I started it up around 3 months ago and only took 6 to 7 goes > which I thought was really good as have no choke cable fitted / coke flaps wired open.
Went to start it last month and it just will not have it !!!!!!
I have checked for spark and its there on all plugs /  Electronic Dizzy fitted > new plugs fitted shortly before it went into unit.
Thought it might be the fuel gone off > only about 1/2 gallon in tank > so went and got 5 gallons of shell V-Power.
The plugs are getting wet with petrol.
Timing has not been changed so same as when I drove it into my unit.
I have stripped the carb and checked for blocked jets > all seem clear.
Batteries fully charged and spins the engine quite quick.
Apart from beating the engine with a big stick any tips on what to check next would be good.
Ta in advance.
Malc.
If nothing has been touched since the previous start up and all leads and timing etc are exactly the same: pull the plugs out and dry them out in the oven. Also run the tips over the hob if they are gas.
Had a similar problem with mine, plugs getting wet after been sat for a long time. After drying the plugs out and refitting them warm, it fired straight away
Thanks but its the same as when I parked it up.
I will have a go in the next few weeks as want to start driving it for the Summer > more than likely I will strip it all down recheck static timing / firing order / spark etc.
Cheers
Malc
Thanks
I had them out yesterday and warmed them with a blowlamp  > when I next turned it over it tried to fire then wet the plugs again.
I will have another go in a few weeks as working in London > Early start / late finish > Hopefully it will start as want to drive it soon.
Cheers
Malc
Fuel probably has gone off and the 5 gallons has diluted that in the tank but as it hasn't run, you've got whole carb float bowls full of the crap - which doesn't light and just wets the plugs! Drain the bowls, good squirt of easy start and try again with fresh fuel actually in the carbs.
