jayson2.3pinto Posted March 3, 2007 Report Posted March 3, 2007 weber alpha kit is ok but the ecu is locked and can only be accesed from weber approved dealers personaly i have seen jenvey throttle bodies to be good and titan roller bodies even better but as for ecu motec or omex both are reprogramable with out changing chips like weber alpha you could upload your other map via com port if you was running nitros etc if you was going to change your map using weber they could program you another chip so you could remove your chip with one map and push fit another chip with another map personaly i would like to upload via lap top my map , as for weber i have seen this run very good
