flyingbanana Posted August 25, 2007 Report Posted August 25, 2007 im sandblasting everything metal that sits in the engine bay ie brake servo,crossmember etc..also doing the struts ,but cant decided what to paint them with its either 1.etch,primmer then paint or 2.straight hammerite or 3. powder coating what option would you choose?
JONA Posted August 25, 2007 Report Posted August 25, 2007 Powder coatinmg is the better option as far as durability. Very hard when finished and also the best finish IMO. Downside is the cost. A friend has just had 2 calipers done at a cost of £30. Hammerite does not cut it for me. The etch primer, primer, top coat is the best idea unless you go silver cos you need to laquer it and if the bits get warm, the laquer goes yellow and spoils the finish Steve
Mr Sam Posted August 25, 2007 Report Posted August 25, 2007 im Hammeriting all my bits and bobs after wire brushing them all down
GT_Jim Posted August 25, 2007 Report Posted August 25, 2007 im doin my x member with zinc primer and hammerite but the servo should be ok with normal paint as i dont think it would get that hot i sprayed the rad on the cortina with halfords matt black heat resistant paint as a primer then went over it with normal celulose and it was fine
flyingbanana Posted August 26, 2007 Author Report Posted August 26, 2007 just found out where my dad works they do powder coating so hopefully should get a quite a bit done fairly cheap
