ok measure the size of hole and measure length you need then, contact rally design and ask them. otherwise just buy a shitload of different bolts till you got a suitable pair, jus make sure you use high tensile, hope thishelps mate
:oops::oops::oops: sorry m8 didnt see ur first post. think rd is gonna get a bit of flack tommorow. if there stuff dont use nomal size bolts y dont they supply them with. down the bolt shop i brought a big bag of bolts for less than £4 :shock:
an update on these problems. rang rally design about the collar size on the inner bush. basicly they had a bad batch of bushes with the collars not drilled big enough to take the standard 3/8 bolt. they stuck two new bushes into the post and i got them today :mrgreen: top guys :thumbsup:
