DEP Posted October 11, 2007 Report Posted October 11, 2007 I would like to change over to a hydraulic clutch on my cossie escort Does anybody know whats involved in converting a cable clutch to hydraulic, Is there a particular cylinder to use or a kit you can buy off the shelf. Many thanks.
escort21 Posted October 11, 2007 Report Posted October 11, 2007 Give Dave at Retro Ford a call he does hydraulic ones which fit on the input shaft he'll sort you out and tell you what master you need as well
kev16v Posted October 11, 2007 Report Posted October 11, 2007 u need a bias box with hydro clutch as he said dave does the cossie conversion give him a call there easy to do
105Ian Posted October 12, 2007 Report Posted October 12, 2007 Got one of Dave's kits on my cossie Anglia , works a treat gives a lovely light pedal to
RETRO_AL Posted October 12, 2007 Report Posted October 12, 2007 I have a tilton kit from gpr raceware which costs about £350 then you need to get your bellhouing machined a few mm, and you will need a pedal box to suit, which is the most expensive bit of the conversion if you want i can dig out the part numbers
DEP Posted October 12, 2007 Author Report Posted October 12, 2007 Cheers guys, Got a bias box already, but obviously running a cable, Will i have to replace the whole Bias box?
RETRO_AL Posted October 12, 2007 Report Posted October 12, 2007 Cheers guys, Got a bias box already, but obviously running a cable, Will i have to replace the whole Bias box? yes you will need a peddle box with the clutch peddle like your brake peddle(if you know what i meanlol )
Guest MK1gaz Posted October 12, 2007 Report Posted October 12, 2007 R.A.C.E. do a decent peddle box and cylinders so just sell your one to fund it . Burtons do a clutch cylinder kit which fits into the bell housing
