m1c Posted October 13, 2007 Report Posted October 13, 2007 really should find me a haynes manual. but until then.... anyone tell me which cable it is to disconnect for the auto choke? i assume its same on all pinto engines? and the distance it takes to floor the accelerator is shite, feels like an inch or so - should it be more?
Kelvfoozinda Posted October 13, 2007 Report Posted October 13, 2007 Is it an electric or water choke? My pedal goes into the floor, but as long as the idle is right then the distance should be the same depending on what carb you have.
oliwally Posted October 13, 2007 Report Posted October 13, 2007 You need to buy a manual conversion to get rid of the choke wether its water or electric operated. Sounds like your throttle cables had it if your only getting and inch of travel.
