m1c Posted December 1, 2007 Report Posted December 1, 2007 assuming the engine was mounted, how would you connect it to the prop?! appologies if this is in the wrong section but im only after a basic answer, i dont expect a detailed explination! cheers
alladdin Posted December 1, 2007 Report Posted December 1, 2007 replace the sprocket which is splined on, with a cush drive doughnut 3 bolt afair or just a prop flange then bolt on a prop. parts are available.
Muttley MK2 Posted December 1, 2007 Report Posted December 1, 2007 AS above but I would recommend a cush drive as it gives a smoother take up of power
