im getting stuff sorted for refit
i sort of used bits of info i found on the web
can any body give me deffinate info on parts needed to convirt
does read a bit err
has any one converted there x flow dizzy from points to electronic
i have brought a bosch dizzy plug and coil from later fords i think mk3 escort they said
can someone confim parts needed and any tips on how its done
wiring firing order and so on
cheers
im just using a distributor off a late mk2 fiesta as they were electronic few wires to splice and dice, set your timing then all you need do is change the rotor arm/dizzy cap as and when :thumbsup:
does read a bit err
i have brought a bosch dizzy plug and coil from later fords i think not in here mate lol they said
cheers
eek my post has been edited
i never said i like mk3 escorts just thats the bit my part came from
lol :lol:
you can use the mk2 fiesta dizzy in a rwd drive ford mate, your posts confuse me though, could you try explaining what your mate told you and what car you have gotten the parts from?
i will find info i found and sort out
i got to brand new bosh dizzy's cos i think i got the wrong one. then a coil from a cosworth cos thats wot i was told i needed for a stronger spark
i aint sure of donor car bits was selected from im suew it was the mk3 escort with the x flow block
could have been fiesta
now watch i bet my post gets edited again for swearing
iv got a mk1 cortina and im running a x flow in it
