im gonna be running a mildley tuned x flow with twin choke webber
iv just dug out all me bits while the garage is clear
and iv found 4 inlets manifolds all of them are slightly differnt
can any one point me in the right direction as to wot one i should use as in are there better than others and so on
cheers
all of them fit x flow and take weber.
some are short as in stuby others seem longer.
from the gasket face to the back enge
Be careful with the longer one - Not sure what the engine bay is like in a Mk1 cortina but on my Mk2 escort I found that that a 4" inlet manifold (approx) pushed the carbs too near to the brake master cylinder. Consequently I fitted a shorter item (can't remeber the length but 3" seems about right). Everything now fits but there is no space for filters (just 16mm trumpets).
Dan
