has anybody used one? i am sick of faffin about with the point and stuff to try and get the timing right, i would love to be able to aford a bestek kit, but i can't, so i am lookin the these, they look simple enough, and cheap only $39 so about 20 quid, just wondered if anyone knew anythin about them?
http://www.hot-spark.com/
That doesn't look bad mate. Hall effect electronic ignition systems are still being used today within ECU's for engine managment. I made a system once upon a time for my Vespa scooter :oops:
Anyway, all that will do is replace your contacts and condenser, it will not change or modify your advance curve. So if you want to get the best out of a tuned engine you will have to use a distributor from someone like Bestek or run mappable electronic ignition. (Thats if you have a tuned engine).
Looks good to me :wink:
