:thumbsup: finally managed to bleed my brakes through........after re-sealing mastercylinder and then changing it for a new one then realising the pipes at the rear were higher then the nipples i managed to get a pedal woooo hoooooo, i was so enthused i finished my exhaust down pipe and made half the exhaust, now if i can only stop the clutch slave cylinder bleed nipple from seeping past ill be 9/10's to driving it again lol :lol::beer:
Guest MK1gaz
Yes it's like foooooking naparm !!!!!!! :shock::shock::shock: . Be affraid of brake fluid pots inside your car unless you drive dressed in tin foil !!!!!!!! :mrgreen:
