Dropping the pinto into my mk1 in a min - would I be right in saying that the longer RS engine mount goes on the drivers side??
Thanks Baz....
Will update with pics in a while!!
Alan G is lending me a helping hand - will have to start of a restop thread!
i think i should come over and see all these escorts, my wives family is from Waterford perhaps go there to :thumbsup: sample some black stuff and ive heard Ireland is good for the crack!! :mrgreen:
What manifold are you going to fit m8?
Your dead right, the black stuff is at it's highest quality here - ye should organise an OSF run to Ireland - and Baz the craic is mighty!!
Anyway - we've the engine dropped in - and guess where we're caught - fooking sump - the previous pinto that was in it (previous owner) ran a steel sump so thought we could get away with it! It's fouling the crossmember, any way around this??
Posse, using a 2" 4 branch mate!
If its an ashley one m8 you will have to mod the engine mount ie cut the mother out of it .Also what rack have you got short stem or long?
you need a alloy RS sump and pick up pipe :thumbsup:
or use steel engine mounts that are 10mm longer than the rally design style ones like i have :wink:
