johnny_h Posted April 15, 2008 Report Posted April 15, 2008 Can someone tell me what this reading is? I'm trying to time up my cam using the "HT method" in classic ford and have bought a DTI but can't read the fookin thing! I was taught in metric but do know that Inches are measured in 8th's and 16th's but this gauge makes no sense at all. Printed on the front is 0.005" so I guess that means the gauge is measured in five thousands of an inch. This is where it gets confusing. Do I need to divide the measurement by 5 to get the reading? Also the gauge reads clockwise 5, 10, 15, 20, 25 and then goes back 20, 15, 10 ,5 ???? This is a minus reading by the way. Please help decipher this dinosaur language.
johnny_h Posted April 15, 2008 Author Report Posted April 15, 2008 Just phoned Baty and found out the increments are half a though each. Still can't read it tho lol
V8ian Posted April 15, 2008 Report Posted April 15, 2008 That DTi is imperial, as you know, the incrememts are in ,0005, which is half a tho" each major section is between the figures is 5 thou, so each small incriment is half a thou, in reality you are only using it as a indicator to check rise and fall of the cam, so the type of DTi is not a problem, you get about 4thou to every 1/10th of a mm
johnny_h Posted April 15, 2008 Author Report Posted April 15, 2008 Cheers Ian, So that reads 92.5 thouh? Is this 0.925 ???
V8ian Posted April 16, 2008 Report Posted April 16, 2008 Reads 0.0925, 0.925 is nearly an inch, = about 24.5mm
