mr shag Posted May 11, 2008 Report Posted May 11, 2008 i have a pinto with the sierra injection which is coming off and a pair of carbs fitted what i want to know is can i use the injection fuel pump with a pressure regulater to suit carbs or should i change the fuel pump cheers chris
105Ian Posted May 12, 2008 Report Posted May 12, 2008 You will strugle to get the pressure down enough using a fuel regulator , you would be better off getting the correct type of facet type electric pump for carbs .
Toby Posted May 13, 2008 Report Posted May 13, 2008 You may still need a regulator even with a facet.
mr shag Posted May 13, 2008 Author Report Posted May 13, 2008 thanks for that change of pump it is then
rallyesport04 Posted May 15, 2008 Report Posted May 15, 2008 use a regulator with a facet pump dcoes run around 3-4 psi all day
