kays mk2 escy Posted May 15, 2008 Report Posted May 15, 2008 Hi, i just bought a cockpit, electronic rev counter. It has no wiring diagram. There are Orange & Black wires exiting counter above the stat Red,Green,Black. Can anyone help with what they are for (i rekon lights) & where they connect to. Cheers
Mr Sam Posted May 15, 2008 Report Posted May 15, 2008 black to earth red to ignition green to either - or + of the coil i forget which something along those lines the 2 you allready have one of them must go to the coil to pick up the signal so you should be able to stick your green straight to that
Mr Sam Posted May 15, 2008 Report Posted May 15, 2008 normaly neg side of coil thought it was but couldnt be sure
