Retro-gone. Posted August 8, 2008 Report Posted August 8, 2008 just to be different.. ive drilled my cambelt cover. got these water pipe inserts we use at work, they are stainless and polish up lovely. fit nicley into the holes (will cut em down before permanantly fixing em) once the belt cover is painted and all the stainless sleeves polished and fitted it should look good.
5hane Posted August 9, 2008 Report Posted August 9, 2008 hey m8, how about 'flare' them holes like on the uide in cf mag ? http://www.frost.co.uk/item_Detail.asp?productID=9120&frostProductName=Hole+Flare+%281in%2E%29&catID=13&subCatID=18&FrostCat=Bodywork&FrostSubcat=Forming bit expencive but bet you can find cheaper on ebay... also will loook ace
