bomber1 Posted November 25, 2006 Report Posted November 25, 2006 can anyone explain the diffrence or do they do the same job or do they do diffrent jobs but can they be used together
Mr Sam Posted November 25, 2006 Report Posted November 25, 2006 there was a write up on anti dive kits a month or so ago in retro ford, they fitted one to project capri
Gareth Posted November 25, 2006 Report Posted November 25, 2006 A doulbe width kit is basically double width A.R.B brackets. While, an anti dive kit is a lenght of rectangular box section that bolts onto the chassis A.R.B mounts that lowers the angle of the A.R.B stoppin the front end 'diving' under heavy brakin, makin the car more stable. Perfect for fast road use and competition
bomber1 Posted November 25, 2006 Author Report Posted November 25, 2006 right thanks guys just the last bit can they be used together
bomber1 Posted November 25, 2006 Author Report Posted November 25, 2006 the reason im asking is i thought i was getting an anti dive kit when ive recived the double width kit so if i can use both i will keep the dwk and order the adk
Gareth Posted November 25, 2006 Report Posted November 25, 2006 Yeah u can, Might need to redrill the ADK to suit the DWK U'll also need wider bushes to fit the DWK. Just in case theyre not together All the DWK does is stiffen up the ARB. Tighter cornering
bomber1 Posted November 25, 2006 Author Report Posted November 25, 2006 ive been lookin in the rally design cataloge & they say the dwk does tighten the arb a bit but not as well as the adk
Gareth Posted November 25, 2006 Report Posted November 25, 2006 TBH m8 I havent fitted one to my car yet Not much point ATM, it's not finished yet If u dont need the DWK, then sell it m8. It'll get some of the costs back
bomber1 Posted November 25, 2006 Author Report Posted November 25, 2006 tbh i dont know what i want/expect from these 2 items & probaly talking sh1t just confused / flumoxed at i didnt get what i thought i was getting
Gareth Posted November 25, 2006 Report Posted November 25, 2006 I'd ring em then send it back. there's nothin more annoyin than gettin fooked about
Retromotorsport Posted November 26, 2006 Report Posted November 26, 2006 The reason the the Anti-Dive kit works better is that it has 3rd bush in the middle so stops the bar flexing under braking too............. When you brake, the outer arms of the ARB are pulled back, the middle of the bar goes forwards as it bent under the bracking force. The 3rd bush stops this. All Anti-Dive kits come with the bushes and Double Width brackets. When fitting it you may want to get some Mk2 ARB mount brackets, there is a difference between Mk2 and Mk1 TC brackets, or you may find you need to shorten the Antidive kit but 18mm from memory. I cant remember the exact combination that all fits up as i make my own ARB brackets for adjustable castor ... so most of the standard stuff goes in the skip
