crapichris Posted October 30, 2008 Report Posted October 30, 2008 when you put in new halfshaft bearings on a capri do you use a bit of hermetite on the outside of the bearing between the bearing and axle body before fitting? I have replaced one and the axle has leaked some oil over the rear brake.
