vibrating_Cake Posted February 3, 2009 Report Posted February 3, 2009 ****URGEEEEEEENT!!!!*** the ignition barrel on the capper is well and truly stuck, the key wont turn it for love nor money, wiggled the steering wheel so much that the steering wheel lock is also on now! URGENTLY NEEDED!!!!!! a IGNITION BARREL LOCKSET WITH KEY!!!! FOR A MK3 CAPRI!!!! anyone got any????? can i use any of any other OSF with the blade type key????? like an old fez/escort/granny???? please help needed asap, i have work tomorrow night and the car is stuck 20miles away in a friends street!! lol! also where can i get them new??????? how do i find from ford etc????
vibrating_Cake Posted February 3, 2009 Author Report Posted February 3, 2009 http://cgi.ebay.co.uk/Ford-Capri-MK2-3- ... 240%3A1318 http://cgi.ebay.co.uk/cortina-mk4-5-ign ... 240%3A1318 http://cgi.ebay.co.uk/mk1-escort-igniti ... 240%3A1318 http://cgi.ebay.co.uk/VINTAGE-FORD-ANGL ... .m63.l1177 any of these fit... Also... if i JUST got the ignition barrel ittself, how would i separate mine from the car to fit the new one if the key doesnt work... and how would i get the steering lock off to????? i.e. how do i remove the old barrel and fit the new one to get it all working!
bigdaz27 Posted February 3, 2009 Report Posted February 3, 2009 scafold tube over the barell that will get the lock of and screw driver in the black box 2mins and your away fords are dead easy to pinch i had A misspent youth
bigdaz27 Posted February 3, 2009 Report Posted February 3, 2009 dont think im a car steeling mary im talking 10years ago maried with 3 kids now clean noes for 8 years
vibrating_Cake Posted February 3, 2009 Author Report Posted February 3, 2009 scafold tube over the barell that will get the lock of and screw driver in the black box 2mins and your away fords are dead easy to pinch i had A misspent youth i dont want to hot-wire my own car... i want a key that works, so someone else who fancies a go cant do it themselves lol.
Copey Posted February 3, 2009 Report Posted February 3, 2009 scafold tube over the barell that will get the lock of and screw driver in the black box 2mins and your away fords are dead easy to pinch i had A misspent youth i dont want to hot-wire my own car... i want a key that works, so someone else who fancies a go cant do it themselves lol. at least it would get your car home though and not left on the road
vibrating_Cake Posted February 3, 2009 Author Report Posted February 3, 2009 scafold tube over the barell that will get the lock of and screw driver in the black box 2mins and your away fords are dead easy to pinch i had A misspent youth i dont want to hot-wire my own car... i want a key that works, so someone else who fancies a go cant do it themselves lol. at least it would get your car home though and not left on the road its a nicer area than mine so its fine there for now lol
bigdaz27 Posted February 3, 2009 Report Posted February 3, 2009 i thourt you wanted to get it of the road and home safe so you could work on it if you have tools where the car is the you could just drill out the 2 bolts that hold the barel on they have no heads on them if you did what i said befor you could still drive the car just dont leve it any where to dogey
emu Posted February 3, 2009 Report Posted February 3, 2009 To remove just the barrel and leave the lock casing on the column you need to be able to turn the key. As Bigdaz says, you can remove the whole lock assembly from the column. Its held on with two shear bolts (the hexagon heads break off when you tighten them up) You can normally get them undone with a hammer and small chisel. If your lucky then someone will have already had it off and replaced the shear bolts with ordinary 13mm headed ones
evil knievel Posted February 3, 2009 Report Posted February 3, 2009 if you cant pull the key out then the barrel isn't turning all the way back, the steering lock bolt has probably failed. could ask my dad what you need to do to get the key out if you like mate, he's been a locksmith for 30 years
vibrating_Cake Posted February 3, 2009 Author Report Posted February 3, 2009 if you cant pull the key out then the barrel isn't turning all the way back, the steering lock bolt has probably failed. could ask my dad what you need to do to get the key out if you like mate, he's been a locksmith for 30 years oh the key will go in and out easy enough but it wont turn
vibrating_Cake Posted February 3, 2009 Author Report Posted February 3, 2009 To remove just the barrel and leave the lock casing on the column you need to be able to turn the key. As Bigdaz says, you can remove the whole lock assembly from the column. Its held on with two shear bolts (the hexagon heads break off when you tighten them up) You can normally get them undone with a hammer and small chisel. If your lucky then someone will have already had it off and replaced the shear bolts with ordinary 13mm headed ones so ill need to buy a new entire lock assy???? think these are available from ford??? (silly question) got any pics etc of what i need to get ahold of with a key?????? anyone got any ? lol
evil knievel Posted February 3, 2009 Report Posted February 3, 2009 oh sorry i misread it has probably got a stuck wafer, put wd40 in the lock, but the key in and tap on the end of the key as if your trying to tap it into the lock. wiggle it at the same time. if it is a stuck wafer this will free it up.
evil knievel Posted February 4, 2009 Report Posted February 4, 2009 scafold tube over the barell that will get the lock of and screw driver in the black box 2mins and your away fords are dead easy to pinch i had A misspent youth i dont want to hot-wire my own car... i want a key that works, so someone else who fancies a go cant do it themselves lol. it wont be the key. if there was something wrong with the key it wouldn't work in the doors, it is definitely a stuck wafer mate.
Retro-gone. Posted February 4, 2009 Report Posted February 4, 2009 dont think im a car steeling turd im talking 10years ago maried with 3 kids now clean noes for 8 years do you wear a burberry cap and tuck your tracky bottoms in ya socks
OldskoolSue Posted February 4, 2009 Report Posted February 4, 2009 oh sorry i misread it has probably got a stuck wafer, put wd40 in the lock, but the key in and tap on the end of the key as if your trying to tap it into the lock. wiggle it at the same time. if it is a stuck wafer this will free it up. mine got stuck a few months ago,sprayed with WD40 and after a bit of giggling it was ok worth a try
bigdaz27 Posted February 4, 2009 Report Posted February 4, 2009 dont think im a car steeling turd im talking 10years ago maried with 3 kids now clean noes for 8 years do you wear a burberry cap and tuck your tracky bottoms in ya socks :shock:l lol no im to old for all that
evil knievel Posted February 5, 2009 Report Posted February 5, 2009 oh sorry i misread it has probably got a stuck wafer, put wd40 in the lock, but the key in and tap on the end of the key as if your trying to tap it into the lock. wiggle it at the same time. if it is a stuck wafer this will free it up. mine got stuck a few months ago,sprayed with WD40 and after a bit of giggling it was ok worth a try any joy cake man?
caprinerd Posted February 5, 2009 Report Posted February 5, 2009 you only had to knock the snap bolts out and disconect the switch assembly and you would have been able to drive it youve knackered that now wobbly bun
vibrating_Cake Posted February 5, 2009 Author Report Posted February 5, 2009 you only had to knock the snap bolts out and disconect the switch assembly and you would have been able to drive it youve knackered that now wobbly bun ive bought a new one so we drilled it out for the sake cause we were pissed off with it. new ones been sent recorded delivery, should be here tomorrow. all it is a case of now is connecting the plugs back up and starting her up.
