since fitting the new pads 2 miles ago the car is slightly pulling to the right under braking, the more pressure i put on the brake pedal combined with higher speed braking the more it pulls, im bedding in the pads as always and havent done any serious braking yet, do you think itl settle? ive fitted scores of brake pads in various cars in the past so its something that comes easy to me,
ps, the brakes were perfect before fitting the new pads.
silly question have you got copper slip on the pad face or has the caliper seized where you pressed it back in to fit the new pads give the peddle a stamping on to see if that sorts it
Guest cortinamad-gonetoo
bleed the side thats pulling :thumbsup:
