My womans astra passed its mot on friday but with advisories. All the brake pipes are just starting to corode. Been told if she leaves them, they'll get worse and probs fail next time and cost a lot to replace. But the mechanic says, if they were cleaned up and surface rust removed, then greased/oiled they've be ok. Can anyone advise the correct way to do this?
I assume they are steel then?
Just my opinion, but if you oil them you won't be able to tell if they are weeping.
Learn how to make your own pipes, then it won't cost much if you do need to replace them. It isn't difficult or expensive. :thumbsup:
When I bought a cheap car about 3 years ao, it had an advisory for the same thing, Baz105e cleaned them with (I think) a little scotchbrite, smeared grease round them, and they passed the next 2 MOT's after that, no problems.
