what manifold and carb is used on the mondeo to race it have heard of them being hard on the track and my son in london wants to start up and wants me to give him a hand but has got a mondeo and told him to scrap the injection as it aint aloud but need to replace it
cheers mate think as far as i know, its speedworth as he`s that part of london so wimbledon is his local track im use to tsr, found that speedworth dont race as hard but each to their own and cheers for the info
  • 3 weeks later...
2 ltr cortina mk5 carb and the manifolld needs a little drilling of a couple of the fixing holes but its not hard and works perfect you can use a vauxall manifold but then you need to make an adapter plate for the carb
The 2 litre pinto manifold doesn't fit the Zetec at all. Only two ports line up far too long, and the whole thing sits on the piss.
The CVH manifold is the one to use as all the ports line up. I just fettled them to suit the oval ports of the Zee as CVH has round holes. I then had the carb mounting boss machined up and welded to the CVH inlet manifold. Bought an adaptor plate from Retroford for £25 plus the manifold came from him as well. Got my mate to do the welding. All works quite well.
Have seen the Vauxhall carb and manifold used though, that seems to work quite well too.
  • 1 month later...
Usher engineering are also the guys to talk too as they now knock out ready to go manifolds for Bangers and Mondano Rods.
http://www.usherengineering.co.uk/
Took my set up to a rolling road a few weeks back, went in with 121hp at the fly came out with 138. Thats 32/36 carb, RS1800 130 standard cams and megajerk ECU. I think that pretty good for carb set up from injection.
i got him sorted with the cvh manifold and he`s been out finished the first race no placing but was blitzed by a massive follow in by a bluebird on the second race but he loved it and has been bitten by the bug and is ready to go out again he lives in london but is racing for tsr at kingslynn bit of a treck but im in norfolk and use to go to smallfields and areana essex as well as local, funny how the traveling dont seem to matter where racing is concerned
anyway a big thanks for the tip on the manifold set up on the zetec
