Airbag Posted May 12, 2009 Report Posted May 12, 2009 When I use my car in anger my second gear crunches when I engage it. In normal road use it is a bit notchy but OK, it’s only when I change up or down to second at higher revs. What’s causing this and is it time for a replacement? I don’t want it to explode when I’m out and about or drag racing! Cheers
Admin Vista Posted May 12, 2009 Admin Report Posted May 12, 2009 Sounds like a worn syncro, it'll continue to get worse but could last like that for some time. I'd try giving the box an oil change and see if that helps at all
Airbag Posted May 12, 2009 Author Report Posted May 12, 2009 Sounds like a worn syncro, it'll continue to get worse but could last like that for some time. I'd try giving the box an oil change and see if that helps at all I'll give it a go! Thanks
Takeshi Posted May 13, 2009 Report Posted May 13, 2009 Worn syncro rings, My Capri was like this. Still going now after thousands of miles
