so i got the bit i needed to remove the head bolts from the cosworth head
i gone though the way i needed to undo the bolts and have fund two bolts the are rounded off
these are0 the star type head bolts
does anyone have a tool to remove the bolts
or is it a case of drilling the tops off then try and remove the studs once the head it off
HELP PLEASE
i have a set of sockets at work that have a slight reverse thread in them. basically you hammer the socket on and as your turn it grips the bolt and will spin it out
i think these are avaliable from the likes of screw fix and machine mart not snap on etc but they will be good enough for the job you need to do
james
Don't think they will work on a head bolt could be wrong though.
I would just drill the head off the rounded ones once the tension is off them you will probably find you can undo them by hand.
If you drill the heads off you will then be able to get the head off.
The ones still in there will be sticking out of the block enough to get some grips on them. As said, they will probably come out very easily once you can get at them.
