Something in the back of my memory says T16 is a granada Mk2 caliper, if it is, its the same mounting bracket spacing but you need shoulder bolts from a TR6?? same piston volume as the p16 so the master cyl can be left as before with a P/M 16, but the pad area is the same as the well used princess calipers,
