fergus mk2 Posted August 4, 2009 Report Posted August 4, 2009 I bought a mk2 escort power steering kit at ford fair and im having a few problems its not working . its either the ecu or the control box for the resistance (this is new). i was wondering does any one have a wiring diagram for the ecu and do you no if its expensive. or if theres any common problems?? thanks for any advice
Mr Sam Posted August 4, 2009 Report Posted August 4, 2009 i saw the company selling them seems a very odd thing to want todo to an escort but then i spose it makes parking ALOT easier does the kit not come with any contact details of the company?
livewire7116 Posted August 5, 2009 Report Posted August 5, 2009 I have a corsa b kit to go on my mk2, not using the control box and its only 4 wires, main earth and main live then a switched live from a relay then a wire goes to the rev counter, you only really need the adjuster box for fwd set ups as it helps compensate for torque steer, when you first drive with it you will find yourself turning it on and off as you wont like the feel, then you just get to the point wondering how you drive without out it
