Chris! Posted August 17, 2009 Report Posted August 17, 2009 Is there anyway of doing it without converting the car to negative earth? Would it work if I put the radio wires straight to the battery so they dont go through the loom?? Thanks
vibrating_Cake Posted August 17, 2009 Report Posted August 17, 2009 wouldnt it just be a case of connecting the + to where earth usually would be and - to where + would usually be? and remembering to switch it off when you get out of the car (no "ignition positive" as it would be an ignition ground so to speak?)
Chris! Posted August 17, 2009 Author Report Posted August 17, 2009 wouldnt it just be a case of connecting the + to where earth usually would be and - to where + would usually be? and remembering to switch it off when you get out of the car (no "ignition positive" as it would be an ignition ground so to speak?) I did wonder about that, would it be safe???
vibrating_Cake Posted August 17, 2009 Report Posted August 17, 2009 errrr.... if theres a good fuse in-line dont see why not...
Chris! Posted August 17, 2009 Author Report Posted August 17, 2009 can anyone confirm this will be ok?
TwoLitrePinto Posted August 17, 2009 Report Posted August 17, 2009 what plonker makes a positive earth car in the first place ???? whats wrong with the traditional negative earth!
Savvi Posted August 17, 2009 Report Posted August 17, 2009 Change the car to neg earth I've not tried it but read somewhere you can't wire the radio but i don't know ? It's easy to change a car though.
Fiesta Steve Posted August 17, 2009 Report Posted August 17, 2009 Don't forget the stereo chassis maybe 'earth' and your car body isn't
Chris! Posted August 17, 2009 Author Report Posted August 17, 2009 Change the car to neg earth I've not tried it but read somewhere you can't wire the radio but i don't know ? It's easy to change a car though. But that means changing my rev counter which ive just paid a fortune having re built
bigdaz27 Posted August 17, 2009 Report Posted August 17, 2009 i found this web site loots of good infomation on + to - earth http://www.lotus-cortina.com/electric/convert.htm
Chris! Posted August 17, 2009 Author Report Posted August 17, 2009 To be honest im not going to change it to negative earth, if i have to ill run another battery in the boot
Savvi Posted August 17, 2009 Report Posted August 17, 2009 That's a good site and very well explained
Trevmk3 Posted August 18, 2009 Report Posted August 18, 2009 To be honest im not going to change it to negative earth, if i have to ill run another battery in the boot you dont need a radio anyway Chris you coming tomorrow mate?
Fiesta Steve Posted August 18, 2009 Report Posted August 18, 2009 Just wire it in as normal whats the fuss all about I had a CD player in my Anglia, no problem
baz105e Posted August 18, 2009 Report Posted August 18, 2009 apparently positive earth was something to do with reduction of corrosion didnt work tho did it
