SebringRS Posted December 26, 2009 Report Posted December 26, 2009 Hi, just got a wireless adapter for my 360 this christmas, im tryin to set it up now so i can go on Xbox Live for the 1st time Its all in correctly, its connected to my NETGEAR home router, but when i press "Check Xbox Live Connection", it will start the test, but then will pop-up saying "There is a problem with your connection, cannot obtain an IP Address" I go to "Configure Network" but it shows the IP address???? I've tried putting it in Manually, tht didnt work either I'd be greatful for any info, on where im goin wrong or how to fix it Tom
2.8i Cossie Posted December 26, 2009 Report Posted December 26, 2009 you need to check and make sure that your router can allow you to add more devices and assign an ip address to them. I only know how to use the bt hubs not netgear sorry.
SebringRS Posted December 26, 2009 Author Report Posted December 26, 2009 Ok, im sure google with have the answer
