MK2 escort sump guard fitting issue and TCA question........
Hi all.
I am just wandering if you can fit a 6mm clubmans sump guard kit to a mk2 that all ready has a full width rally design anti dive kit fitted? Also does anybody know whare i can get hold of any TCA washers for a mk2 escort, the big ones that fit onto the anti roll bar that clamp the TCA bushes together.
Have you tried main dealer? think you will find they are same as mk3/4/5 escorts and possibly many newer ford with an arb/tca set up. Dont forget there is a steel sleeve which goes on there as well but if using poly bushes they are normally supplied
as for the sumpgaurd the triangular brackets go on the outside of the anto roll bar mounting brackets and should fit your dw kit with no fouling problems, if you have anti dive then the centre mounting point may cause problems depending on what brackets you have.
