Equinox Posted January 19, 2010 Report Posted January 19, 2010 Just removed the viscous from the Capri but want to just put a blanking nut on the thread, its a 32 mm nut that the viscous had on and with a left handed thread had anyine ever used a large cap nut just to make it look a little better than just the thread sticking out ?? Thanks
livewire7116 Posted January 19, 2010 Report Posted January 19, 2010 you can get a basic water pump which will do away with the viscous set up, you just need the steel pulley for the fan belt to sit in.
