cortinasgoneforaburton Posted March 6, 2010 Report Posted March 6, 2010 Hi guys and gals ive got a post on here about changing an axle on a mk5tina but i am being told to check diff ratio now i know how to do it but what i am gonna do first on tuesday when i start is to jack the rear wheels off floor, mark a tyre and prop and see how many times prop goes round for one full revolution of wheel i suppose the less turns the better if anyone could also do this if they know there diff ratio so i have got somthing to compare
Guest cortinamad-gonetoo Posted March 6, 2010 Report Posted March 6, 2010 isnt there just a tag on your diff?
Guest cortinamad-gonetoo Posted March 6, 2010 Report Posted March 6, 2010 i dont know how you do it by jacking car up and turning wheel but you count the teeth on crown wheel and count the teet on pinion then divide crown divided by pinion you maybe have the 4.11 some 1.6 saloons did
bortaf Posted March 7, 2010 Report Posted March 7, 2010 WHS /\ just check the diff tag, if it aint there do the old count the prop V's wheel bit, some tippex and a jack and your away
