Guest cortinamad-gonetoo Posted April 1, 2010 Report Posted April 1, 2010 swhats the best way to deal with this dent its a outward dent i tried rubber mallet and normal hammer with a piece of flat wood is it a case of knocking the dent right in and filler and skim flat its annoying me
mexman123 Posted April 1, 2010 Report Posted April 1, 2010 Get a blunt plastic implement, such as the end of an upturned screwdriver, place it on the dent and GENTLY tap the metal point of the screwdriver with a ballpein or similar hammer. Do not try to remove the dent in one hit, just keep tapping it gently steadily increasing pressure over a period of 20-30 taps...It will minutly decrease with every tap, therfore minimising or even completely removing the need to fill. If the dent is not just a high spot, but a 'long' dent, keep moving the end of the screwdriver over and along the dent, as you tap it. It will take time, you should be aimong to spend at least 10 mins on a dent like that, but GENTLY !!
Guest cortinamad-gonetoo Posted April 1, 2010 Report Posted April 1, 2010 cheers but one problem i think i have every typr of hammer but a ballpein one will a mormal small hammer do ?
mexman123 Posted April 1, 2010 Report Posted April 1, 2010 Yes, but GENTLY, GENTLY...Each minor tap, will decrease the dent by the smallest invisible amount, but it will take time.....Spend at least 10 mins, it could take upto 50 taps or even more to do it, Just do'nt whack it..nice and easy...
Guest cortinamad-gonetoo Posted April 1, 2010 Report Posted April 1, 2010 ok cheers i will try tomorrow depending on the weather
PaulMags Posted April 1, 2010 Report Posted April 1, 2010 hi if you have access to a dolly[oblong shaped thick piece of metal if you dont no what one is]place it on the inside over the dent then use a flat hammer with some masking tape over wrapped over it as not to damage paintwork and gentlly tap it in.you'll still have a few ripples but thats your only option without filling and spraying it.
Guest cortinamad-gonetoo Posted April 1, 2010 Report Posted April 1, 2010 i didnt know what one was but i couldnt do that as its impossible to get to the back of it theres a strengthening thing behind it i dont know what you call it (its the inner frame of the bonnet )
PaulMags Posted April 1, 2010 Report Posted April 1, 2010 seems like your knackered then mate you'll have to hit it in with a pointy hammer and skim it over and paint it.sounds easy but i do it for a living.
Guest cortinamad-gonetoo Posted April 1, 2010 Report Posted April 1, 2010 seems like your knackered then mate you'll have to hit it in with a pointy hammer and skim it over and paint it.sounds easy but i do it for a living. youre welcome to do mine you can finish the whole bonnet because it does my head in i hate bodywork
Guest cortinamad-gonetoo Posted April 1, 2010 Report Posted April 1, 2010 put a sticker on it no thanks
oxb1l Posted April 1, 2010 Report Posted April 1, 2010 the first dent on the misses car annoyed the feck out of me but after that i never bothered,i cant even wash it now it just annoys me how much it cost and the fact she doesn't care some of these dent master guys are good at matching dents like u got there and usually under a ton l8r Bill
