RossMK2 Posted June 26, 2010 Report Posted June 26, 2010 Anyone got any tips on fitting the bush where the tca bolts to car?
bomber1 Posted June 26, 2010 Report Posted June 26, 2010 cut it in half plop it in fit sleeve fit tca sorted most poly bushes come pre cut
Stiggy Posted June 26, 2010 Report Posted June 26, 2010 Don't cut them in half they fall apart in double quick time. Put them in boiling water so soften, a decent vice helps and use lots of fairy liquid (other washing up liquids are available) as lube. Or Poly bush, even though I preferred rose joints.
RossMK2 Posted June 26, 2010 Author Report Posted June 26, 2010 I dis cut them in end will probz put poly bushes in in a couple of years anyway
over_head_cam Posted June 26, 2010 Report Posted June 26, 2010 Fairy liquid and a vice would have sorted it
RossMK2 Posted June 26, 2010 Author Report Posted June 26, 2010 We did put it in fairy liquid and in vice but still wouldnt go in the bushes are heavy duty ones and like rocks
Stiggy Posted June 27, 2010 Report Posted June 27, 2010 We did put it in fairy liquid and in vice but still wouldnt go in the bushes are heavy duty ones and like rocks Used to be called RS bushes when I was a lad That's why I mentioned boiling water.
RossMK2 Posted June 27, 2010 Author Report Posted June 27, 2010 Well it done now so it to late I know for next time
