Hi all, can anyone help me, ive just changed my mk1 escort 1.6 xflow from an automatic to a manual, everythink is in fine but when i put the gear stick in i only get 1st & 2nd gear, if i take the stick out i can get all 4 gears & reverse, any ideas plzzzz.
Also why cant i get photobucket to do photos on this site, thxxxxx steve........ :?
If you pull the rubber gaitor up there's a circlip, remove that then try fitting the stick, this helps to get it in the right place, remember to put the circlip back in after it's tight.
Also knock the lock taps over as they can come lose !!!!
Cheers i"ll try that as i did take the plate of to check the box was good....
I bet thats your problem mate
Ive done it so i know :roll:
:lol:
let me know how you get on
