ok come back from chelsea bridge last night left the car in garage got the car out in the morning check under the bonnet and its coverd in oil looked like it was coming from the breather box thingy on side of engine so cleaned everything up changed a couple of pipes went for another spin gave it some beans checked under bonnet again oil every where so i think it is coming out of dipstick any ideas cheers engine is crossflow
Sounds like you have a build up of crank case pressure, is the engine standard?
I've fitted a catch tank and fitted an oil filler cap with a breather on also, anything that does spit out get caught then :wink::thumbsup:
