has anyone fitted rear disc conversion from capri sport ? if so do you know what side of the bearing holder does the caliper plate go? ive looked at the picture, it shows it to be inbetween bearing holder and axle . im sure if you do it that way it the bearing would leak oil and the half shaft would have movment the thickness of the plate
it takes the place of the backplate, make up some paper gaskets and silicone then both sides
thanks for that . i cant be thinking right thats common sence (:
