escort21 Posted October 4, 2010 Report Posted October 4, 2010 are 1300 and 1600 fuel pumps the same on a 711m block? my escort struggles to get fuel and wont start if left for more than a day due to no fuel and its pissing me off
baz105e Posted October 4, 2010 Report Posted October 4, 2010 check the fuel pipe isnt blocked or has any holes in it, run an airline back down the pipe into the tank to clear it and try it after that, also check the brass olives on either end of the pipe
escort21 Posted October 4, 2010 Author Report Posted October 4, 2010 Done all that, its all fine, I have a fuel filter that is see-through fitted in line near the carb and its never full, you can see the fuel really struggling to into the filter
baz105e Posted October 4, 2010 Report Posted October 4, 2010 maybee your pump is shot then mate, if you want to be really sure that your getting fuel then buy a leccy pump and pressure regulator. im pretty sure the pumps are the same on a 1.3 and a 1.6 tho
escort21 Posted October 4, 2010 Author Report Posted October 4, 2010 Yeah ive got an electric pump but cant be arsed to fit it at the moment as my other car needs work mot, i'll try another pump for now. Are 681 and 711 pumps different? seem to remember they are...possibly the finger shape, that could be the problem
baz105e Posted October 4, 2010 Report Posted October 4, 2010 think so, the part that follows the cam is of diffrent length, your best bet is to send wpe a message or put a post up in his 'room' on here, wayne knows everything
