same size and compound yes, you want uprated compound ? try rolls royce pads, some rollers use M16 calipers (2 per wheel) but use a harder compound and are cheaper than green stuff but dont get cheap ones cos they will be all the same compound.
Also there's 2 M16 calipers, a larger one with bigger pad area on the cortiona P100 and larger engined Mk2 grannys :thumbsup:
cheers mate, i have a set of 2.8i ghia granny calipers as well and there huge. bolt on the same but wouldnt get anything less than a 15" wheel over them. :thumbsup:
, i have MNk2 granny calipers on 3 cortinas 1 with 13" sports steels, 2 with 13" laser alloys :wink:
Here's the 2 calipers side by side, hardly huge in comparison teh pad hole is larger is all and on teh granny they use 14" as standard so how you get only 15s ?
Workshoprebuild85.jpg:? :?
edited for being a dick :oops:
Yep just with a bigger pad hole, the outer body is the same though that's granny and normal M16's in that pics :thumbsup:
they go
P14 smaller engined escorts
M16 normal (capri, RS escort, cortina and small engined grannys)
M16 vented 2.8 capri
M18 non vented (cortina P100 2.3 granadas)
M18 vented 2.8i granadas
normal M16 caliper
M18 vented (note the spacer betwen the 2 halves of the caliper and teh larger pad hole
ignor the M or P that just denotes wether metric or imp threads, the M16 and M18s use the same size pistons so no master cylinder mods are required :thumbsup:
The M18 was offerd by ford on the 3.0 X paxk capri as a brake upgrade along with vented discs which were robbed from Xpack Rs escort and calipers from the granada but they would have used 7 inch RS/ronaL 4 spokes.
I see what you meen by looking larger actually sorry :oops: the hump is wider and i spose could catch on a differant offset wheel ? but as i say i have em on 3 cortinas on 13s
I thinks that pretty much it for fittments i'm sure somone will add if i've missed anything :thumbsup:
