I have an electric cooling fan mounted to the rad on the engine side, should it blow air forwards through the rad or suck air through it?
It should suck the air from the front of the car towards the engine.
If you have it blowing through the rad from the engine side then it will be blowing hot air from your engine onto your radiator.
