Retromotorsport Posted February 12, 2011 Report Posted February 12, 2011 well thats funny cos mark showed alwyn how to do them in the first place And people ask me what camber/castor/spring rates i use.... wether they get the correct answer or not depends on if i built the car
105Ian Posted February 12, 2011 Report Posted February 12, 2011 I have the master cylinders mounted upside down on my pedal box due to lack of space , once bleed out they work fine . But have to say they where a pain in the arse to bleed out and if I had a way of changing them so they could be mounted normally I certanily would . Ian..didnt we go 60 degree AP's ... They are just normal girling cylinders mounted upside down , don't you remember the fun we had holding the pedal box upside down while getting someone to push the pedal untill 11 oclock at night . If I had 60 degree AP's would they all bleed out normally ? Have looked at them on Demon tweeks site and there are lots of different options and says 52 days delivery so may have to ask you to have a look for me to help make sure I get the right ones . Cheers Ian
Retromotorsport Posted February 12, 2011 Report Posted February 12, 2011 I'm sure i mentioned the 60's after that night ... i'll have to try and locate one for you to have a looksie .. think Andy P may have one in his stores
105Ian Posted February 12, 2011 Report Posted February 12, 2011 Pretty sure you did metion them that night , but have to say after finally getting to drive the car properly for the first time that night I was to excited to remember anything If you can get hold of one would be good to check it and pop down for a kebab
vibrating_Cake Posted February 12, 2011 Report Posted February 12, 2011 Just a top tip... when i got the capri bias pedal box done, i send off the std capri pedal box to peter lloyd, and they cut, welded, tested, fitted master cylinders, set up the bias bar and everything so all i had to do was plumb it in, they even put a notch in the accelerator pedal and powdercoated it. Never once had a problem with it!
Guest Posted February 12, 2011 Report Posted February 12, 2011 I got so annoyed with skinning my knuckles getting to my pedal box I threw it in the bin and fitted floor mounted pedals from Tilton.
