nik_plant Posted February 23, 2011 Report Posted February 23, 2011 Does anyone do top mount restamping or is there a way of doing it?
nik_plant Posted February 23, 2011 Author Report Posted February 23, 2011 How much would I be looking at? Cheers mate
TILBROOK Posted February 23, 2011 Report Posted February 23, 2011 i take it you mean number stamps, machine mart do them £30. then u can do it your self.
nik_plant Posted February 23, 2011 Author Report Posted February 23, 2011 i take it you mean number stamps, machine mart do them £30. then u can do it your self. I use them stamps at work when fitting dimension plates, but they never look and good I want them to look like they did originally if I do it
PIG Posted February 23, 2011 Report Posted February 23, 2011 pm markjabber on turbosport mate.he is very good and uses the proper ford stars on them.cheaper than mr nunn as well hth
PaulMags Posted February 23, 2011 Report Posted February 23, 2011 pm markjabber on turbosport mate.he is very good and uses the proper ford stars on them.cheaper than mr nunn as well hth m8 does he do new vin plates and stamp them as mine are knackered
banarama Posted February 23, 2011 Report Posted February 23, 2011 yes dont forget to put the stars before and after
w p e Posted February 23, 2011 Report Posted February 23, 2011 to do it 100% you would need 5/16= 7mm ford stamps [ not easy to come by] close is close enough
banarama Posted February 23, 2011 Report Posted February 23, 2011 to do it 100% you would need 5/16= 7mm ford stamps [ not easy to come by] close is close enough ringing days
mexman123 Posted February 24, 2011 Report Posted February 24, 2011 Roy Nunn charges £50..... Nice work if you can get it...
