PISTONMELTER5 Posted August 6, 2011 Report Posted August 6, 2011 Hello, been advised to come on here n list what i have n get some advice from ye Ok so i have a harris performance 1690 fwd xflow, all lightened and balanced, leccy dizzy, huge ports, double valve springs and ap clutch all lightened and balanced flywheel etc etc, but cant rememeber what cam and size the valves are think its a stage 1 with a 234 engine could also have a baffled sump, uprated oil pump and new water pump will check for sure! Anyway i also have full steel rocker gear, alloy rocker cover, twin 40 DHLAs on xflow high flow manny with magard linkage. I also have a standard xr2 engine which i was told has had some work but cant be sure, its disassembled but complete and comes with a standard xr2 carb i also have a set of diesel fiesta 1.6 con rods and crank Im looking to get rid of everythin as ive another set up pretty much bought so need cash! im not looking to make a fortune just to pretty much cover my other plans so if you arnt keen on the asking price let me know! n ill see what i can do am looking to sell most off at once and will do a deal on a job lot! I jam looking on some advice price wise thats why i posted here rather than in the for sale section as i dont know what i should be asking?? I want the stuff gone asap as i have a fella waiting on cash for the other engine! I also have a set of koni coilovers and adjustable leda rears with -40mm spax springs all for a mk1/mk2 fiesta that i would be willing to let go if necessary to raise funds for my new kit Any help greatly appreciated
Davewrc Posted August 8, 2011 Report Posted August 8, 2011 If you want to sell the stripped xr2 engine i may be intersted if your close?
PISTONMELTER5 Posted August 8, 2011 Author Report Posted August 8, 2011 well im in ireland mate! but a mate a mine goes back and over every couple of weeks who can bring it over for a couple a quid if your interested
Ste-V Posted August 10, 2011 Report Posted August 10, 2011 I may be interested in the suspension if the price is right? I'm from Blackpool so if he sails to Morecambe/Heysham then I'm only down the road..?
