samurai Posted August 23, 2011 Report Posted August 23, 2011 What is the best way of fitting the brake pipes to a bias peddle box? Last time i fitted them it was a right pain! Even stripped the threads off the master cylinders because the space is so tight around the box! Is there such thing as a right angle brake pipe connector?
James HPE Motorsport Posted August 23, 2011 Report Posted August 23, 2011 Are you running braided? If so, the best way is by a banjo. It's like a ring that goes on the end of the pipe with copper washers ether side and a special bolt that goes through the middle! Like this http://www.ebay.co.uk/itm/Venhill-Braid ... 1160wt_689 You can even get angled ones aswell! Hope this helps
samurai Posted August 23, 2011 Author Report Posted August 23, 2011 Are you running braided? If so, the best way is by a banjo. It's like a ring that goes on the end of the pipe with copper washers ether side and a special bolt that goes through the middle! Like this http://www.ebay.co.uk/itm/Venhill-Braid ... 1160wt_689 You can even get angled ones aswell! Hope this helps I dont have braided lines but dont mine having them, i bet they will be expensive.
samurai Posted August 23, 2011 Author Report Posted August 23, 2011 Found this http://www.brake-lines.co.uk/?gclid=CLf ... 4Qodig6f8w
James HPE Motorsport Posted August 23, 2011 Report Posted August 23, 2011 Yea they are pretty expensive! I think it cost me £250 to do the whole car in braided! You can buy the line and fittings separate and make it yourself! It's pretty straight forward and definitely worth it!!!
