i fitted mine down as per the diagram worked fine
hmmm... i had fitted mine that way, now after paint i turned it round for some reason and realised only after plumbing the thing!
I found the following info on a site:
If the filter is on top it can get water in and clog the internal filter or corrode parts once it reaches the vacuum chamber. I've also run them on top ( they DO look better like that ! LOL ) with no immediate problems but I didn't know better at that time .
Can I assume that since the servo will be inside the car, there wont be any water getting in it, and therefore should be fine?
